digiphotonerd
Posts: 121 |
Hmm -- is this the isolator you got from Parts Express? If so, it's not surprising that it's causing problems, since even its *marketing* description says "Operating Frequency: 100 MHz to 1 GHz".
If you look at this table, you'll see that frequencies below 100MHz are needed for analog channels 1-6, 95, and 96 (other channels may also be affected -- it's hard to tell without real frequency response data for the isolator). Your cable provider *may* also use those frequencies (and/or frequencies above 1GHz) for its digital service.
You should get much better results with a higher quality isolator like the Iso-Max VRD-1FF from Jensen, which has a bandwidth of 2MHz - 1.3GHz and costs ~ $60. Or, you could try breaking the ground loop at other places, as described on this page or this one.
- digiphotonerd
POST #4 | Report this post to a moderator
| IP: Logged
