Warning: include() [function.include]: URL file-access is disabled in the server configuration in /home/avsforum/archive.avsforum.com/avs-vb/history/archive_functions.php on line 31
Warning: include(http://archive.avsforum.com/avs-vb/history/header.php) [function.include]: failed to open stream: no suitable wrapper could be found in /home/avsforum/archive.avsforum.com/avs-vb/history/archive_functions.php on line 31
Warning: include() [function.include]: Failed opening 'http://archive.avsforum.com/avs-vb/history/header.php' for inclusion (include_path='.:/usr/local/lib/php') in /home/avsforum/archive.avsforum.com/avs-vb/history/archive_functions.php on line 31
Pages:1
Painless TheaterTek Upgrade From Ver 1.2 To 1.5?
(Click here to view the original thread with full colors/images)
Posted by: Big Picture
I have TT ver 1.2 installed and working fine. I want to upgrade to ver 1.5. In reading the TheaterTek support forum this is apparently a tough upgrade. Is there a painless way to do this upgrade?
My OS is Windows XP, video card is Radeon LE/7200, audio card is Auiophile 2496.
Thank you.
Posted by: Axel
Finally no longer painful...
See here and here
___
Axel
Warning: include() [function.include]: URL file-access is disabled in the server configuration in /home/avsforum/archive.avsforum.com/avs-vb/history/archive_functions.php on line 37
Warning: include(http://archive.avsforum.com/avs-vb/history/footer.php) [function.include]: failed to open stream: no suitable wrapper could be found in /home/avsforum/archive.avsforum.com/avs-vb/history/archive_functions.php on line 37
Warning: include() [function.include]: Failed opening 'http://archive.avsforum.com/avs-vb/history/footer.php' for inclusion (include_path='.:/usr/local/lib/php') in /home/avsforum/archive.avsforum.com/avs-vb/history/archive_functions.php on line 37
vBulletin Copyright ©2000 - 2012, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2012 - Created by Stefan "Xenon" Kaeser Modified by Adam J. de Jaray
